Local Time 02:16 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : F&P
MacGyver
Posted: 03:44am 20 May 2009
Will someone kindly tell me what F&P means?
Copeville, Texas
Posted: 03:55am 20 May 2009
Fisher and Paykel, white good manufacturer founded in New Zealand.
We use the motor from their Smartdrive range of washing machines.
http://www.thebackshed.com/Windmill/WhatFP.asp
http://www.thebackshed.com/Windmill/FPdiss.asp
The motors are as common as beer cans down under, which is why they have taken off as a windmill alternator.
MacGyver
Posted: 08:15pm 20 May 2009
Oh! Thanks. I would have never figured that one out on my own.
I don't modify others' stuff; I make everything from scratch.
:O)
Copeville, Texas
Posted: 02:37pm 21 May 2009
MacGyver, a while ago you posted that you prefer to convert your windmill output to air pressure. Interesting, I understand you have no pictures but could you tell me just what air pressures you can achieve before that thing stalls?
MacGyver
Posted: 06:19am 04 Jun 2009
Pictures are on their way. I'm rebuilding all my stuff and putting together
a Web page that'll have a photo gallery, plans and everything else.
As far as pressure goes, the sky's the limit. It depends on how well you
seal your pump and how much leverage your prop gets. I use both piston
pumps and rotary pumps. I like the rotary ones the best, because they
require only a minimum of machining. I make all my own stuff, including
check valves.
Power is a trade-off. I deal with "shaft" horsepower and therefore don't
rely on the engine's "speed" to build power. My air engines develop
maximum torque at zero rpm. That's handy! If I want more power, I can
up the pressure or increase the length of the power stroke; either method
gives me more power.
Think of storing air pressure in terms of how hydraulic brakes work and
you'll find it easier to understand.
The original "steam" locomotives had two "engines" that were double-
acting cylinders set 90-degrees apart; one mounted on each side of the
boiler. Each engine had a cylinder about 14 inches in diameter with a
stroke of about 21 inches. The working pressure of the steam was
usually nearly 2,000 psig. With just two "engines" (not to be confused
with the "boiler" which is what everyone thinks is the engine) a steam
locomotive could pull a train full of cows a mile long up nearly any grade!
Slowly, mind you, but with "power" like there's no tomorrow. Expanding
air works in a similar manner.
Typically, I run my air engines on less than 40 psig. I'm working on a
two-cylinder air engine that can be built with a drill press. I use a lathe,
but not everyone has one of those, so I'm gearing it to the abilities of all
the shade-tree mechanics out there. This particular model uses "external
pistons". I'll let you think about that one before letting the cat out of the
bag. It'll be on the Web site soon enough.
To further answer your question, when the tower valve is shut down and
the mill is pumping against a dead-head of trapped air, the piston pumps
stop almost immediately. The rotary pumps slow down and depending on
the "memory" (hint) of the cylinders, it can either finally stop or just run a
lot slower. In any event, I've never lost a blade to over-speeding.
I typically set the piston pump windmills with a blade pitch of 45 degrees.
I use a Jacobs style, up-wind turbine arrangement (3 blades). The rotary
pump windmills are powered with blades set at approximately 15 degrees
each. These pump more "volume" than pressure. If the system pressure
is up, they just lope along and are fun to watch, but don't do much in the
way of any "work".
Copeville, Texas
Xmaswiz
Posted: 06:10pm 26 Apr 2011
have you started this project yet?
Santa Maria, CA.
Noel
MacGyver
Posted: 02:44am 07 May 2011
Xmaswiz
Have I startet this project yet . . . hmmm . . . . yes and no. You see, I have a couple of drawers in my shop I call "damfino" drawers. That's because "dam-'f-I-know" what's in them. There are air engines, air pumps, pistons, cylinders, check valves . . . you name it. I've been at this a long, long time and so to answer your question, basically "yes".
I have a problem shared by most "inventor" types. I don't finish stuff before starting something new. To that end, there are several (read that oodles of) projects that are built and work, but I've lost interest or canibalized parts to build some other new, brainy idea. That's just the way it is; it's not a bad thing nor is it a good thing, it just is what it is.
I will eventually get around to posting ALL my silly projects on this 4m, but if you will kindly slip over to the Solar section, you'll see that this week I was in need of some free hot water, so I spent a few days building a solar application for my house. That means the time it took me to build the solar thingie, was NOT spent building any of the hundreds of others I've started and not finished. Hope that sheds some light on your question.
It's not easy bein' me!
. . . . . MacEdited by MacGyver 2011-05-11
Copeville, Texas
