Local Time 00:49 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Feeding your micro turbo
Greenbelt
Posted: 04:45am 02 Mar 2009
A ram pump My design but any is fine if it works.
another way to charge batteries
Posted: 12:54pm 02 Mar 2009
Interesting, but how does it work ?
What makes the "cycle valve" move?
I assume this has to be just at the right depth, can you indicate where the stream water level would be?
Greenbelt
Posted: 05:56pm 02 Mar 2009
The Ram pump is very well named,Water is allowed to gain momentum and then suddenly it has nowhere to go, this Inertia generates high pressure for a moment.
I have drawn a operational diagram, hope this helpsjavascript:AddSmileyIcon
Greenbelt
Posted: 06:19pm 02 Mar 2009
The Rampump is generally set up on the creek bank. a 2- 3
meter drop in the lead in pipe will make a good setup. should have a minimum of 60 feet lead in , this assures a
good mass of water in motion. you can google for lots of
info.
Posted: 11:33am 03 Mar 2009
thanks, I get it now. Very clever
The long lead in is the key to its working...
There was another pump shown on the "inventors" program here a few years ago. It looked like a disk sitting on the creek bottom - no lead in pipe. It was also supposed to lift small water quantities to a large height. They never said how it worked, I'm still wondering...
Posted: 11:53am 03 Mar 2009
Hi Greenbelt,
can you give any data on cycle valve operating frequency, and the relative volume of water required to pass through the cycle valve compared to the volume of water pumped.
Gordon.
Greenbelt
Posted: 07:06pm 03 Mar 2009
Yes , The moving water is the key.
The flexiblity of this device is amazing. If you have a stream with plenty of water but only 1.5
meter
head within your property then a 15 CM. lead in pipe with pump valves to match could give you
5 meters of head (guess) and lots of water. Below is a link to, a build it yourself instructable,
This one is small but obviously does a big job well, also cheap.
The disk type pump you mention may have been a vapor pressure system, as I recall the system
used heat absorbing paint on pipes exposed to the Sun to generate a pressure for moving the
water. I never did understand the raft and disk in the pond. Perhaps it was a barrier to keep out
the leaves and driftwood. it did not work.
http://www.instructables.com/id/Worlds_greenest_water_pump/
Posted: 09:50pm 03 Mar 2009
  GWatPE said  can you give any data on cycle valve operating frequency, and the relative volume of water required to pass through the cycle valve compared to the volume of water pumped.
from your lack of first hand info, I can only assume you have not made any operating units, or the ratio of water needed to boost the height is high. I suppose this would not matter if the creek flowed all year, and the energy went past regardless.
Gordon.
Greenbelt
Posted: 12:33am 04 Mar 2009
Gordon;
The pump cycle is generally close to 1 second but is variable with different head pressures
The length of the lead in pipe the working pressure and volume of water pumped per cycle.
Example;
A large pump with a 2 meter head and long lead in pipe with a low pressure output, say 20
psi.(you work out the kilogram sq..) I'm not well schooled for metrics, this kind of setup will have a
longer cycle time because water will flow into the air chamber for a longer time before the back
pressure will equal the ram pressure., more water pumped per cycle.
The waste water is actually quite small when the pump is adjusted correctly. The head water surges into the valve chamber forcefully and the cycle valve closes quickly loosing about a half liter or less. there are a lot of variables that effect the output. but as a ratio about 2.5 to 1 loss.
If water is to be pumped to 30 meters or more the waste water will increase because the pump
will need to be adjusted to hold the cycle valve open longer so that maximum velocity is achieved
in the lead in pipe.
Greenbelt
Posted: 07:56pm 04 Mar 2009
More about A RAM PUMP;
A seemingly mysterious device with the uncanny ability to pump water without a motor, crank,weights or any visible means of power.
Performance;
The pump cycles about once per second. An average size pump will output 1/2 liter each cycle, depending on the pressure head and length of the lead in pipe. There are 86400 seconds in one day, That is 86400 / 2 = 43200 liters of water. = 10800 gallons and deposited as high as 30 meters above the stream it came from. Economy don't get better than this.! How does it work.?
Imagine a 2" diameter X 60 feet long solid steel bar moving along peacefully at 1 meter per second ,Bang ! hits A BRICK wall, Now think of this as a rod of water not nearly as heavy but still a non compressible solid.
The cycle starts with the cycle valve open, this gives freedom to the water in the lead in pipe. The Head water on a downhill slope accelerates, the light spring tension on the cycle valve can no longer hold it open as water surges through the limited opening.
The valve slams shut (brick wall) there is 60 feet of moving water in the pipe that must stop instantly, aint gonna happen, the pump has another valve that is spring loaded closed, The CHECK VALVE, when the cycle valve slams shut the instant pressure rise opens the
check valve and water surges into a temporary receiver where trapped air will compress and cushion the pressure shock wave.
When system pressure and ram pressure have balanced, The check valve closes, The compressed air moves the water on
to its destination and the water lead in pipe recoils slightly, creating a moment of pressure below atmospheric value, this permits the cycle valve to open with a little help from the adjustable tension spring. the pump is now configured to start a new cycle.
Posted: 10:16pm 04 Mar 2009
Hi tinker,
don't forget to do an energy balance to calculate how much water is needed to create the increase in water pressure.
A 2m head in the lead pipe, to produce 30m lift, will require 15L of water to flow through the lift valve for every 1L water pumped to 30m, at 100% efficiency for conservation of potential energy, and more to allow for kinetic energy losses.   The ratio 2.5L produced at the higher pressure for 1L loss does not gel with me.
I have heard of ram pumps used to supply drinking water quantities to a header tank, to allow a gravity fed reticulation.
Gordon.
Greenbelt
Posted: 07:50am 05 Mar 2009
Gordon
I do not see any reference to 30 meter lift with a 1 liter loss,{From my reply.) sorry for the jagged format, I accidently bumped the post button on my previous reply.
A large pump with a 2 meter head and long lead in pipe with a low pressure output, say 20psi.(you work out the kilogram sq..) I'm not well schooled for metrics, this kind of setup will have a longer cycle time because water will flow into the air chamber for a longer time before the backpressure will equal the ram pressure., more water pumped per cycle. The waste water is actually quite small when the pump is adjusted correctly. The head water surges into the valve chamber forcefully and the cycle valve closes quickly loosing about a half liter or less. there are a lot of variables that effect the output. but as a ratio about 2.5 to 1 loss.
The above is in reference to a large pump with a low lift
having a 2 meter head and a long penstock, lead in pipe.
If water is to be pumped to 30 meters or more the waste water will increase because the pump will need to be adjusted to hold the cycle valve open longer so that maximum velocity is achievedin the lead in pipe.
Posted: 12:59pm 05 Mar 2009
Gentlemen, thank you for explaining workings of this this pump to me. My question was for a purely academic interest, I like to know how things work.
Unfortunately, living in the middle of suburbia, there are no handy streams nearby I could plant such a pump in
Greenbelt
Posted: 08:13pm 05 Mar 2009
No problem;
My original post was intended to show a possible method
of making a few watts of power. Ranchers and farmers in America in the 1800's made use of ram pumps to irrigate and
provide water for the livestock, the first ones came from Europe. they are much more robust than some would have you believe.
MacGyver
Posted: 01:22am 16 May 2009
I think this is called a trombe or something like that. Mother Earth News did
a lot with this in the early '70s and I think if you went to their Web site,
you'd be able to "search" through their archives. I remember reading plenty
of "technical" and "hands-on" information back in the day.
Copeville, Texas
Greenbelt
Posted: 03:26pm 16 May 2009
This is sometimes called a "HYDRAM" or "HYDRAULIC RAM"
Folks who are Interested in this subject should take a look
at this link,
http://www.howtopedia.org/wiki-en/?title=How_to_Make_a_Hydra ulic_Ram_Pumps%3F&printable=yes#How_a_hydram_works
