Local Time 00:59 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Pedal generators
Mason
Posted: 06:24am 30 Aug 2021
A few days ago, I saw a video of a homemade pedal machine to generate electricity, which was very interesting.
https://www.youtube.com/watch?v=zVBR3HNjlYw
Edited 2021-08-30 16:25 by Mason
Godoh
Posted: 06:41am 30 Aug 2021
Nice idea, there are a few problems that have to do mainly with efficiency.
First thing is he did not understand how car alternators work and did not supply a voltage to the field coils.
Second he has now way to adjust the field current so will be supplying maximum current to the rotor field coils which will be about 3.5 amps
Pity he had no ammeter to actually show what current he was actually generating.
A very fit bicycle rider may be able to supply around 750 watts for a while, depending on their fitness level.
The fact that the tv ran off the battery and inverter proved nothing really, it would have worked without the generator hooked up.
The most important bit is how much he was able to generate, and secondly for how long.
I do know of people who use bicycle power for their houses, Peter Pedals of Nimbin in Australia has done so for years.
Pete
Davo99
Posted: 09:21am 30 Aug 2021
Only thing wrong with that idea was the lack of an internal combustion engine or a solar panel.
