Local Time 01:36 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Graphite  graphene backshed  batteries
BenandAmber
Posted: 02:09am 06 May 2020
I have been researching and experimenting with Graphene and graphite
A believe a high energy density diy battery is possible
It may be possible to print or spray the active materials onto large rolls
The rolls could be made to fit in a five gallon bucket
Each bucket would be a single cell with a large amp hour rating but low voltage
These bucket cells could be series or parallel connected for any voltage or any amp hour rating
High grade home made Graphene and graphite can be made and doped fairly easily
Thay have higher energy density then lead acid and a very high cycle life
There are examples of paper batterys
and non-toxic batteries with simple electrolytes
You can get started being amazed with stuff you already have in your kitchen like microwave and blender
Graphene can be made out of old carrots Apple banana peels almost anything
Some are better than others and some will be naturally doped
My goal is a diy battery made from easily obtained or easily made cheap and printable or sprayed ingredients
These ingredients printed or sprayed on a roll to be put in a cheap or free 5 gallon
bucket
Robert Smith on youtube has hours of videos on subject and more
He is incredibly entertaining and is to his field like you guys are to yours
He is truly what I call a great
I never thought to post about it here
I was texting a good friend telling him what I was into and it got me thinking
Some of the world's greatest minds are here on this site
Thay are truly humble generous and wise
Thay shere ideals and work together
Thay are not motivated by financial gain or Pride
Thay Answer to No One But theirselves
Thay have no pressure to use inferior components or rush through
They're free to unlock there potential
Thay can think in untraditional ways
These I think are a few of the reasons
you guy have had so much success
Imitation is the greatest from of flattery
I fill this is the missing link to all that is done on this site
I hope you guys consider watching a few videos by Robet Smith or others about graphene caps and batteries
Thanks for your time and have a blessed
Davo99
Posted: 03:23am 06 May 2020
When you say Low Voltage, How Low and what sort of Ah do you think a bucket size cell would have?
Clockmanfr
Posted: 07:59am 06 May 2020
Yes, I have been working on and looking at homemade batteries.
Something I have been considering to do as a  'How to make a 2v 60kg PLANTE battery' Book.
For the time being the most cost effective solution for power output and material use is the humble PLANTE type lead acid, where both plates of the cell are lead sheet and the immersed medium is sulphuric acid mix, a 15 to 1, where 1 is a 80% sulphuric.
Several things have made this PLANTE cell possible.   1. Polypropylene woven material can be used as a sock separator on each lead sheet.  2. Polypropylene containers made to a particular size can be easily commercially obtained.
So the Finished PLANTE 2v cell can be up to say 60kg in weight, be dismantlable, the acid internally can be minimal as the lead plates with socks can be really tight inside its container.
Disadvantages ….
PLANTE batteries are a pain to set the internal oxides as on charging they need up to 25 charge and discharges over a fairly long time to coat the plate with the Oxide that defines the Anode and Cathode.
I have done a couple of cells and each time I have got the Anode and Cathode the wrong way round, typical!.
In real life Expect only 1/3rd of the AH for a PLANTE battery against a commercial battery of the same weight.
https://docs.exideindustries.com/pdf/industrial-batteries/Plante-Range.pdf
One thing about the PLANTE battery each time the cell is discharged and then charged the battery gets better and better AH.  And life of a Plante battery is incredibly long.
Graphene battery is interesting and I have watched its development, but at present there are just to many variables. But I will keep tinkering as I believe that graphene cells may indeed be usefull and can be self built in the future.
BenandAmber
Posted: 09:49am 07 May 2020
As far as graphene batteries go your electro-light determines your cell voltage
There are many good graphine material already known and tested
like sugarcane vegetable oil Coal many others
High surface area conductivity
what you dope it with and electrolyte determines the capacity
I was searching for best material to make graphite out of but I am now past that stage now
Once you get you're graphene figured out you can add capacity to the cell by choosing electrolytes that hold a charge
Graphene battery is by far cheaper then lead or any other if you make your own materials which is very easy to do
You can make a truckload of graphite for cheap or free
A sealed barrel with hole in bottom
put in a larger barrel with stove pipe fitted to lid
You can make graphene with a autoclave
you can make one cheaply if you cant have a fire outside
Space in between two barrels are filled with scrap wood
The center Barrel is filled with whatever you want to turn into your carbon or graphite whatever you want to call it
The center Barrel has a hole in the bottom this lets the wood gas come out and burn
in between the barrels along with the scrap wood you loaded in there
makes for a clean burn very efficient
Running steam through it activates it
If you make your graphite out of sugarcane it will naturally be doped
If a free waste product is not one that is naturally doped
you can add egg whites or many other things to dope it
after you have your doped carbon
u can activate it by running steam through it
you can activate it in your microwave you can dope it in your microwave
you can do the whole process in your microwave for smaller amounts
Your next step would be to grind it up a small as possible in something like a blender
Sift it regrind what doesn't go through sift
After that you need a slow speed mixer
Easily made with  electric motor and a wire if you don't already own one
You will also need marbles or still bearings or something similar
You put you sifted carbon graphite what ever you wish to call it in you mixer along with water
This sheers the layers off instead of busting them
The difference betweens graphene and graphite is
It is graphene when it is sheared off and really thin
The whole process can be done in small batches in your kitchen
From start to finished test cell
Regular white Elmer's Glue school glue whatever you want to call it
Use under10% ratio mixed with water and you're graphene thus makes a paint
Aluminum foil makes good current collectors
You can also cut out thicker metal for this
The key is to make it small and the same size every time
I would suggest a centimeter square for your active material in the center of the two plates
you will be very surprised at how much energy you will get out of that little tiny piece of paper
You can also have two little squares active material with a piece of tissue paper in between for a separator
There is countless ways to do it watch a few videos and pick one
Kraft paper whatever you have on hand gets painted with you're graphene paint and maybe dust dry on top of paint front and back
You put your tinfoil collectors one on each side of the painted paper
after dripping enough electrolyte to thoroughly wet the cell through
Have something slightly heavy to sit on top of your cell to compress it and hold it together
you hook your alligator clips to the tin foil make sure they don't touch
I usually leave foil hanging on opposite sides
Charge your cell after charged discharge it and note the energy density while discharging
you can use carrots onions seaweed tree leaves any waste product wood sticks out of your yard
it will all make graphite and graphene the structure and quality differs between all of them
It is possible to build a battery by spraying or printing you're graphene onto paper
I thought about making lead acid cells
If I was to go that route I would do a pasted red oxide plate and pasted yellow oxide plate
Both red and yellow oxide are fairly easy obtained form recycling old batteries
I think red oxide forms around 300 degrees and yellow around six or seven hundred degrees don't quote me on those
If you don't mind cutting open old batteries and melting lead you can use the same containers for the new battery
You can make a mold for a grided plate to paste your oxides on and reuse the separator socks
I think it can be done indefinitely
I forget the name of these batteries but if I remember correctly
they are really good batteries that last just as long or longer than regular batteries
I honestly think graphite batteries will be the best way to go
It is a super capacitor and battery
in one
After your graphite testing is done
then you start testing for the electrolyte that holds the most energy
while giving your requirements
The electrolyte will determine your cell voltage
This type of battery can be more energy dense than current lithium or less than lead acid
I do believe even if the  least of these was chosen
it still beats lead acid because of the life of the battery low cost and the simplicity of construction
Boy that's a lot to write
just look of Robert Smith on youtube if you are interested he also has video on red and yellow lead batters
Monkey see monkey do surely you didn't think I came up with any of this lol
This is the future of batteries
God bless ya and have a bless day
Bryan1
Posted: 10:04am 08 May 2020
Rather than invent a new cell take a look at old 4wd stating batteries just tip the acid out in a suitable container then add a saturated solution of baking soda. It will bubble for days so drain out the battery and put a new solution of baking soda in. It may take 4 goes to stop the bubbles but when the bubbles stop time to flesh the battery several times with fresh water. Then make up magnesium sulphate concentrated solution then put the battery on a solar panel I left my first conversion on 4 by 5 watt panel for a month. Now that battery serves as the fan power for the cooling on my listeroid.
Got another donor battery to start and I'm thinking of getting 20 of these to convert and just see off the power off the batteries will power my welder.
Just food for thought
Cheers Bryan
