Local Time 03:38 21 Sep 2026 Privacy Policy
Forum Index : Solar : IMEON 3.6 INVERTER
solarwind
Posted: 03:00am 02 Apr 2015
Hi all!
What is your opinion of the IMEON 3.6 inverter? It has a built in MPPT charge controller, so you do not need to buy one. It is grid-tied, but will do what is needed and gives preference to direct solar usage with battery charging and excess to the grid.
Is it a good buy or do you have reservations?
They give a 5 year warranty which may be extended to 10 years.
Look at the following and tell me what you think, please.
http://www.imeon-energy.com/en/imeon-3-6/
Thanks!
You don't have success until you've tried it!
davef
Posted: 08:31am 02 Apr 2015
Well, it looks like a clever box of electronics. Certainly using any power you generate rather than stuffing it back into the grid is a good idea IF you get less for it compared with what you pay for it.
As my next battery bank for my off-grid system will be LiFePO4 I am surprised that they don't offer that battery option.
Solar is the way to go and if you need some backup when the grid fails it looks like a good option.
Talk to them about LiFePO4 and do some research on using them.
davef
Posted: 09:04am 02 Apr 2015
  Quote  IMEON reduces the cost of solar kWh by 30% compared to traditional (Off-Grid) systems by minimising the use of energy storage. IMEON gives the priority to direct consumption of solar energy, and only stores the surplus of solar production.
Having a bit of trouble understanding what they getting at here.
Are they suggesting that your solar panel capacity requirement is reduced because you are connected to the grid? Well, it would cost me $20,000 to get connected so I would say that they didn't factor that into their overall "efficiency percentage"!
