Local Time 00:22 12 Nov 2026 Privacy Policy
Forum Index : Solar : 12v pumped solar hot water ?
Bernie the Bolt
Posted: 12:24pm 26 Aug 2007
Hi Guys, I am planning to build a solar hot water system, but am unable to mount panels below storage vessel, so am considering pumping using a 12v pump (a specialist item) and driving with say a 15 - 20 watt pv panel. I understand this arrangment avoids the need for controls.(if the sun shines the pumps runs -if not it doesn't)
Any one else have experience of this ?Edited by Bernie the Bolt 2008-03-26
Bernie the Bolt
I'd rather be sailing!
Pt w/field Matt
Posted: 01:48pm 26 Aug 2007
hi bernie seach for words of wisdom from allan s and he used a craig davies 12 v car pump/a maximisser and a 5 watt panel to do the job with a link for the maximisser circuit
matt down south
Pt w/field Matt
Posted: 12:50am 27 Aug 2007
hi bernie made a mistake look under words of AllanS under solar hot water
matt down south
philmountains
Posted: 09:15pm 29 Aug 2007
Hi Bernie Re- storage vessel do you mean Cylinder/calorifer ? also why don't you make it a sealed system with expansion vessel.
I am also one day going to build a solar system on my finca in Spain (once I get a roof on it !), and will start by making a home made panel with 15mm risers onto 28mm headers with fixed to whatever comes to hand, with some nice big thick Kingspan insulation and double glazed unit to trap the heat in, this is just at the idea/ dream stage like most of my project.
PS were abouts are you in France ?
Thanks Phil
Feral
Posted: 02:32pm 30 Aug 2007
Bernie,
What is there that you want to now ?
Is it the design and size of the system or just information on the pumping ?
Bernie the Bolt
Posted: 05:30pm 24 Mar 2008
Thanks Phil, Matt & Feral for replies.
It is just the pumping I need advice on, I was planning on DIY panels totalling about 2-3 sq meters and a storage vessel of 200 litres. ( a sealed system as the storage vessel has a coil in it, I can then put an anti-freeze in the primary circuit)
Phil , I am in the Limousin, moved here from Cornwall 3 1/2 years ago.
Sorry for late replyEdited by Bernie the Bolt 2008-03-26
Bernie the Bolt
Posted: 10:11pm 24 Mar 2008
Hi Bernie,
The pump will probably need to be made from metal, and a sealed unit. The working fluid can reach temps of 65+ degrees C. Be careful using ethylene glycol antifreeze, as leaks into the water side will render the water unsuitable for drinking.
woofnumber0
Posted: 08:42pm 25 Apr 2008
Hi vent it back, not as good as using a pump.hot water will flow down hill.
Woodzy
Posted: 08:25am 14 Jun 2008
Hi all new to the site, been swotting up nicely thanks, great forum.
I hope this site will give Bernie a few tips on his pumping idea.
http://www.voltscommissar.net/K4/kernkraft.htm
cheers
Woodzy
