Local Time 03:52 21 Sep 2026 Privacy Policy
Forum Index : Solar : AC-DC low voltage heating elements
jkis
Posted: 12:42am 07 Aug 2014
is there a difference between AC and DC water heating elements, i have a 250watt 24volt solar panel and was wanting to use it to for heating, i spotted on ebay some low voltage 24volt 600watt elements also some DC thermostats.
cheers stuart
yahoo2
Posted: 02:57pm 07 Aug 2014
Hi stuart,
anything that is DC is a prime candidate for rapid electrolysis, the DC heating elements are sealed to prevent this but the rest of the install needs to be correctly isolated or whatever so there is no electrical path that can eat the tank away.
jkis
Posted: 04:36pm 07 Aug 2014
thank you yahoo2, so i'd be better of with out the thermostat, are the DC elements tougher than the AC ones.
cheers stuart
yahoo2
Posted: 03:20pm 08 Aug 2014
No I am just saying you need to make sure the water tank is not somehow part of the electrical circuit.
jkis
Posted: 07:13pm 08 Aug 2014
thanks yahoo2, i will be sure of that.
cheers stuart
yahoo2
Posted: 02:43pm 09 Aug 2014
you are going to have trouble with arcing on the thermostat contacts with DC at higher loads. You might have better luck with a gadget that converts it to high frequency AC, the only one I can think of off the top of my head it from techluck.com.
I have no idea what they are like but it is worth a look.
jkis
Posted: 06:58pm 09 Aug 2014
worked out to around $300 with freight and rate change, it did mention that you can use a std element, i didn't get to see if the power came out of the MPPT at 240 volts.
not having a good head day, so i may have missed it ;) just wanting to use up what i have here, when i get going properly i can use some water solar panels.
cheers stuart
