Forum Index : Solar : Hot water heating
shawn
Posted: 12:47am 29 Jul 2014
Hi all its been a bit since I've posted, but a little advice needed I was hoping this might work putting PV on the roof series/parallel the dc output to around 300 dc with around 3kw of PV then connecting it straight to the hot water system 240v ac element using the normal thermostat that shuts off the power to the element when temperature reached.
Hope this will work, pros/cons?
Shawn
Posted: 04:03am 29 Jul 2014
Shawn, intuition tells me that a thermostat designed to switch 240V AC would not last as long switching up to 300V DC. A different type of contacts is required for DC switching.
Posted: 11:00am 29 Jul 2014
You could use the existing thermostat to operate a relay that is rated to do the job. You must have your reasons for wanting to use the PV panels but why not use solar hot water panels?
davef
Posted: 01:14pm 29 Jul 2014
Shawn,
A work-mate has designed a system to do this properly. If you want a relay suggestion I'll ask him.
Dave
Posted: 05:57pm 29 Jul 2014
Yep agree with the others, the thermostat would quickly expire ( probably after the first cycle ) switching DC instead of AC, so a high voltage relay or electronic relay would be needed. You will need a low voltage circuit to drive the relay too, say 5, 12 or 24 volts, depending on the relay.
Be careful with safety, 300 volts DC is much much more dangerous than 240 volts AC. Also consider fuses suited to high DC voltage, a standard 240VAC fuses will light up like fireworks with DC and could start a fire.
The element should be fine with DC, provided it does not go too much over 330 volts.
I can see advantages to using electric solar panels instead of water solar panels. No problems with frost, leaks, pumps, etc. Plus you can mount the panels far from the tank, and they would probably have a longer life. But its an expensive option. Water solar panels are fairly easy to find 2nd hand, I paid about $70 for mine, and are very efficient. You would need many more electric panels than water panels to do the same job.
MadRat
Posted: 08:01am 31 Jul 2014
If you aren't too far south then it's more efficient and less costly to use a heat pump in the attic to preheat the water. Hot water storage itself is inefficient, so you're taking an expensive route to be more inefficient.
If you already use propane or natural gas then the natural route is hot water on demand systems.
Go Huskers!
shawn
Posted: 09:31am 01 Aug 2014
Thankyou for your replies your advice is appreciated.
Its for a frend and he already has the PV panils so I think the best advice would be to just buy and connect a grid tie inverter onto them for him to save power.
My system is off grid and I have heaps of hot water
norcold
Posted: 09:58am 01 Aug 2014
For cold country that has ample solar potential, probably solar-inverter-heat pump combination would be the better compromise. Price of heat pump hot water systems will drop as they evolve and become popular. Apparently in QLD you cannot legally install an element hot water system in new houses.
Vic
