Forum Index : Solar : Diode SR5100 ???!!??
toxsickcity
Posted: 12:47pm 01 Jun 2011
Hi Everyone,
I want to know if you think these diodes would be any good (Schottky SR5100) compared to (R-6 1000V 1000Voltage 6A)
datasheet and Ebay Find.
Ebay Link to 5100 Diode
PDF Datasheet
Cheers,
Shaun
EDIT:
Sorry, My array is no more then 3x 22v panels.. (66v-80v)
@ 3.5A
(44 cells @0.5v (22v)Edited by toxsickcity 2011-06-02
Posted: 01:02pm 01 Jun 2011
Hi Shaun
How are you going to use the diodes, as blocking diodes in the array, or elsewhere?
Schottky diodes are fast switching, so work well in switchmode power supplies, etc. For a solar array, a regualr diode will work, but it depends on hows its wired, across the cell or in series.
toxsickcity
Posted: 01:54pm 01 Jun 2011
it will not be required in series because my controllers have built in diodes, perhaps I will,
But I plan to use for shade protection / hotspot protection
basicly 1 Diode in parallel with POS/NEG for each diode
so you think the normal 6A 1000v diode is best, I think I will go that route, as it noticed I wouldnt save too much voltage for the schottky
Posted: 12:20pm 02 Jun 2011
Hi Shaun
The 1000volt rating is a bit overkill, since it will only see a few volts, but if you can get them cheap enough then go for it. The high voltage diodes are usually a bit more robust anyay.
