Local Time 01:56 12 Nov 2026 Privacy Policy
Forum Index : Solar : solar array tracker
brucedownunder2
Posted: 10:33pm 28 Apr 2011
I'm nearly ready to install the tracker electronics . Q. Has anybody here installed a kit or off the shelf type of tracker ?
If so , could you recommend it? I'm worried about talk of "hunting" that is , the electronics can't make it's mind up about whether to stop or keep hunting for that bright area.
Nice to hear from you
Bruce
Bushboy
VK4AYQ
Posted: 02:14am 29 Apr 2011
Hi Bruce
i tried a photo sensitive controller without much success in the end I used a timer to turn on every 30 minutes for a few seconds and a micro switch for parking each end.
I am working on a water ram for the new one for cheapness and reliability as the electronic don't like to be outside.
Foolin Around
