Local Time 01:49 21 Sep 2026 Privacy Policy
Forum Index : Solar : entity I-credit 400 readings
rgormley
Posted: 01:41am 07 Feb 2011
i have the entity I-credit 400 interval meter...
i`m on a single rate 24hour "GD" tariff with origin...
Residential, single rate Tariff Unit Excl GST Inc GST
Domestic - General (Tariffs GD and GR Only)
First 1000 kWh/qtr c/kWh 21.45 23.595
Balance kWh/qtr c/kWh 23.25 25.575
Supply Charge c/Day 62.42 68.662
The entity I-credit 400 unit has 4 main readings (apart from time/date)
04 peak import
06 off peak import
94 peak export
96 off peak export
The meter spits out data on all the outputs,(peak/off peak)
Q: If i don't have off peak tariff (being on the origin GD-24 hr tariff) what figures should i be throwing in my excel spread sheet? considering the meter is logging figure on all settings....
1: Has anybody got a entity I-credit 400 meter ??
2: anybody got a working sample excel spread i can use? (and what data should i use)
Thanks,
Richard
