Local Time 01:15 12 Nov 2026 Privacy Policy
Forum Index : Solar : solar panels and inverters on ebay
Robert_VK2BBR
Posted: 10:55pm 25 Apr 2010
Hi all, did anyone look at the systems (just ended) on ebay. there was 30 off 175 W panels for $12700, and 2.5 kW grid tie inverters for around $1800. pretty cheap, especiallly when you take the value of the recs away.
cheers Robert
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=320517 589926&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=320517 075871&ssPageName=STRK:MEWAX:IT
1555 W grid connect system since Jan 08
both vehicles running on modified, used vege oil.
neil0mac
Posted: 11:46pm 25 Apr 2010
eBay says, "Listings have been removed'. But an eBay search might find them as 'Ended'?
Robert_VK2BBR
Posted: 07:51am 26 Apr 2010
here is a cut and paste from my ebay for the panels...Robert
Solar Panel 175 Watt Mono-Cryatalline x 30
Item condition: New
Ended 24 Apr, 201014:44:19 AEST
Bid history: 0 bids
Starting bid: AU $12,705.26
or
Price: AU $13,000.00
Postage: Local pick-up offered.See more services See discounts | See all details
See postage below.
Payments:
PayPal, Money order/Bank cheque, Personal cheque, Bank Deposit | See details
Pay with PayPal and you may be protected up to $20,000. Conditions apply
Returns:
No Returns Accepted
Seller info
mce.services.australia ( 3 )
100% Positive feedback
Ask a question
Save this seller
See other items
Other item info
Item number: 320517075871
Item location: Mackay, QLD, Australia
Posts to: Local pick-up only
SharePrintReport item
Description Postage and payments
Seller assumes all responsibility for this listing.
Last updated on 11:16:12 AEST, 15 Apr, 2010 View all revisions
Item specifics
Condition: New Brand: Simex
Product Type: mono-crystalline Solar Equipment Type: Panels
Robert_VK2BBR
Posted: 07:53am 26 Apr 2010
here is the inverter
1 x Sungrow SG2K5TL 2.5KW Solar Grid-connect Inverter
MCE Services is the Primary Distributor of Sungrow product in Australia.The Inverter is manufactured and imported Direct on order to your address by DHL.
General Descriptions:
SG1K5TL / SG2K5TL is a transformerless inverter with higher efficiency. Its aluminum housing makes it very compact, robust and light in weight. The direct plug-in terminal port provides easy, safe and reliable cable connection under any circumstances. It can be used for string-connected outdoor small PV power station, or individually for a small house.
Technical Features:
• MPPT efficiency > 99.9%
• Easy-setting multilingual LCD display panel
• Multiple communication interfaces
• High reliability with full protective functions
• Wide DC input voltage range
• Compact design with high quality aluminium housing
• Max. working altitude at 6000m
• Water-proof direct plug-in terminals
• CE certification
Communications:
• RS485/Ethernet/GPRS interfaces
• Computer monitoring software
Safety:
·Full protection functions: over-voltage protection, short-circuit protection, islanding protection, over-heat protection
·Over-load protection
·Standards complied: EN61000-6-1, EN61000-6-2, EN61000-6-3, EN61000-6-4,EN61000-3-2, EN61000-3-3,EN60164-1-1,EN55022, EN50178
Technical Specifications:
Model SG1K5TL SG2K5TL
DC Input
Max. DC Voltage
450Vdc
450Vdc
MPP Voltage Range
150~380Vdc
150~380Vdc
Max. DC Power
1700Wp
2800Wp
Max. Input Current
12A
15A
Max.Number of Strings
1
2
AC Output
Output Power
1500W
2500W
Operating Voltage
180~260Vac
180~260Vac
Operating Frequency
50Hz/60Hz
50Hz/60Hz
Current THD
< 3%(at nominal power)
Power Factor
~1(at nominal power)
System
Max. Efficiency
95%
95%
Euro Efficiency
94.5%
94.5%
Protection Degree
IP41 (indoor)
IP20 (indoor)
Operating Temp.
-25~+40oC
-25~+40oC
Ventilation Method
natural cooling
natural cooling
Humidity
0~95%, non-condensing
Acoustic Noise Level
<40dBA
<40dBA
DISPLAY AND COMMUNICATIONS
Comm. Interfaces
standard: RS485
standard: RS485
optional: ethernet/GPRS
Display
LCD
LCD
Mechanical Data
W | H | D
288|417|126 (mm)
288|467|126 (mm)
Net Weight
10.54kg
12.1kg
Product will be CEC certified at the 1st of May 2010
Any questions please contact before bidding mce.services@bigpond.com
neil0mac
Posted: 09:29am 26 Apr 2010
On the face of things it looks like they are trying to match a 2.5KW inverter with 5.25 KW of panels? Or were there two inverters?
Panel price is about as low as you can expect at present.
The trouble with buying panels etc. on eBay is finding an installer as most installers seem to be tied to companies who only want to supply and install.Edited by neil0mac 2010-04-27
Robert_VK2BBR
Posted: 09:31pm 26 Apr 2010
Yes one would need more than one inverter.
I am lucky in that a good mate of mine is a solar installer....
cheers Robert
VK4AYQ
Posted: 02:39pm 27 Apr 2010
Hi Robert
Looks like a good system to add to your existing one, keep us in the loop as you progress with the project.
All the best
Foolin Around
KarlJ
Posted: 03:45pm 27 Apr 2010
If it sound too good to be true it probably is.
I've settled on $2.66/W locally which works out at $4K for 1.5KW.
Mounting hardware causing me grief, will more than likely use the energy matters stuff.
Bought one of these today
Order Items
Quantity Name SKU Price Subtotal
1 CB, Enclosure & Label Kit (Label Kits: 1x CB Enclosure Label Kit (= $81.00)) CB20 AUD81.00 AUD81.00
SubTotal : AUD81.00
Shipping and Handling Fee : AUD8.00
Tax Total : AUD8.09
Total: AUD89.00
Greenway Energy Online Store
Most mobs / thieves are asking $80 for the DC breaker alone plus $50 for the box + +.
I'm looking at 1.9KW for $5K panels, $1550 inverter $200 cables breakers, $700-800 mounting hardware (will have some spare) and $800 for the installer.
less about $6500 in RECS rebate so $1850 bills for a 1.9KW system bargain!
even Nu energy is asking $5K for 2KW
I'll go bigger when funds allow
neil0mac
Posted: 10:13pm 27 Apr 2010
Karl,
What is a 'reasonable price per panel' for an 'average' install - if such a beast exists?
And by average, I guess is mean, no assistance from the owner to put up racks.
OK, trenching, tracker construction etc. would be extra.
And while I'm about it, is it easier to install the electrics on a tracker (working off the ground and/or trestles or ladder) or a roof?
I am just trying to decide whether my installer labour estimate is too low, adequate, or high. And of course(?), wiring up a big inverter is about the same cost as a tiny one? Have allowed for $100 per (16 or 24?) panel - just for the electrical work, no fixing of the panels in place - for my ground mounted tracker which I think is excessive!Edited by neil0mac 2010-04-29
Robert_VK2BBR
Posted: 10:23pm 27 Apr 2010
Hi Bob , all, I am still dreaming of adding more panels, especiallly ATM when the RECs are such a good price. I would rather deal with someone on the ground in Aus but havent made any firm plans yet. The xyl is a big diode when it comes to funds travelling in the opposite diection hi hi.
cheers Robert
neil0mac
Posted: 10:33pm 27 Apr 2010
OK, I'll bite. What is xyl?
Dingdoc
Posted: 07:34am 28 Apr 2010
"ex young lady" - ham radio talk for wife
VK4AYQ
Posted: 08:03am 28 Apr 2010
Hi Robert
XYL's are always a problem when it comes to money and when they let a bit flow they do a good imitation of a zeener.
Have to explain hoe it will save enough to buy a new pair of thongs every so often.
All the best
Foolin Around
