Forum Index : Solar : Thermal atorage
| zeitfest Guru Joined: 31/07/2019 Location: AustraliaPosts: 702 |
A no-frills cooling storage system , lends itself to off-grid installs, (pS how about a heating/air con section gizmo ?!) Edited 2022-01-02 13:00 by zeitfest |
| Godoh Guru Joined: 26/09/2020 Location: AustraliaPosts: 718 |
Looks like a good system, I have seen systems on the net where they use long pipes buried in the ground as cooling systems. I think that they just blow air through the pipes to bring either cooler air in summer or warmer air in winter into the house. Those pipes are buried pretty deeply from memory. I guess in an area where the ground freezes over they would have to be. Having water drums sounds like a pretty simple setup. Pete |
