Local Time 00:23 12 Nov 2026 Privacy Policy
Forum Index : Solar : Give me an amp
piercy007
Posted: 06:14pm 03 Oct 2008
Evening
If you connect a number of solar panels togther in series you can increase the voltage i.e 3 @ 3 volts = 9v.
Does the same increase apply to the amps?
Also if you did a mix and match do you get an average of the total or the collective?
My middle name is luck mind you my first is bad!
AMUN-RA
Posted: 09:02pm 03 Oct 2008
series volts increase amps stay the same
parralel voltage the same amps increase
what are you trying to achieve just buy a larger panel
Every day the sun shines
& gravity sucks= free energy.
Posted: 02:44pm 04 Oct 2008
  piercy007 said   Evening
If you look closely at a commercial solar panel you will see it has a number of individual cells connected in series to get a suitable terminal voltage.
On the bigger panels you might spot two series strings of cells connected in parallel, you get twice the current of a single series string of cells. You also get a better shade tolerance as if one cell in one string is shaded the other string will still put out power.
You should be able to get your answer from this and what was said in the message above.
piercy007
Posted: 11:37am 06 Oct 2008
  AMUN-RA said   series volts increase amps stay the same
Thanks for that - needed a quick sanity check.
The bid panels are still far to expensive so been building my own by buying smaller (affordable) panels and connectign them togther. As you can imagine the Wattage is low with the crap amps. What I intended to do was add some high ampage panels to the mix to bump it up but needed to know (which I do Know!) which way to connect them
cheers all - all I need know is some sun!
