Local Time 02:18 21 Sep 2026 Privacy Policy
Forum Index : Solar : Cap doubler
Thai
Posted: 04:34pm 28 May 2018
For a cap double, can I use different size uf and voltages. Then connect same together and the parallel them? If so what will be the guestamated
output
Posted: 11:09pm 30 May 2018
No way of knowing as you give us no actual information.
zaphod
Posted: 07:30am 04 Jun 2018
You should know that by adding capacitors in parallel the total capacitance is the sum of the parts, however each capacitors voltage rating must be adiquite for the application but not necessarily the same.
For example on a 12V bus you could have 100uF/25V and 220uF/63V the result would be 330uF/25V.
Cheers Roger
1Kwp DIY PV + Woodburner + Rainwater scavanger :)
