USB development board
Author | Message | ||||
vasi![]() Guru ![]() Joined: 23/03/2007 Location: RomaniaPosts: 1697 |
Hi Downwind, thank you! [quote]Have you tried using posi-resist pcb with UV light to expose the board with. I have used both methods and much prefer the UV light method. If you intend on doing more than one board the UV is far easies and quicker. [/quote] I was tempted to use this method for me but I can't afford it. My long term target is this. I will use it also as a little source of financial gain. [quote]I found sign writers have large rolls of the glossy backed transfer/sticker paper just being discarded, after the vinal lettering has been cut and removed. Just ask and you will get heaps for free. It works well although much thicker than the A4 sticker backings.[/quote] You had to send this one on private. Now I have no chance to find something ![]() Vasi Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
