MMEdit V5.4.3
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6621 |
V5.4.3 has been uploaded. No significant changes to the editor. My next task is to try and update the syntax files. It might be time to add another syntax for the USB range of picomites MMCC has a layout change, speed improvements and more error trapping. ![]() All flash commands are moved from the file manager to the MMCC menu. (Drive A: is still accessed through the file manager.) Delete Library and delete all flash slots ask for confirmation. The number of device families has been reduced and any new or unknown device is assumed to be a member of the picomite family. File manager has also had a layout change. ![]() The top line: TFTP is available on the webmite when connected via TCPIP. Ymodem is available on some picomite variants. IF Ymodem fails to start, it will revert to Xmodem. (TFTP and Ymodem are both much faster than Xmodem) When transferring to a 'mite, you can choose to create a temporary file first. This is more secure and less likely to delete a valid file if the transfer fails. It does require sufficient drive space. Transfers TO the PC always use a temporary file. Progress indicator. It may not appear for small files. It resets to zero once the transfer is complete File name and transfer speed followed by a direction indicator. Abort lets you interrupt a transfer. If you have temporary file selected, nothing is lost. No change to the second line. Next is the device currently connected to as shown by MM.Device$ Below that are 3 "Change to drive" and 3 "copy to Drive" It is the users responsibility to know how many drive their device supports. Jim VK7JH MMedit |
