Bryans Car Club Record Project
Bryan1
Posted: 07:57am 01 Aug 2026
G'day Guy's,
           Well it is time to start my own thread and I'm using several pico 3 computers all working together so the first thing to do was setup the snd.py and recv.py files which handles the wifi between the boards so here is the code
For the PICO1 send.py
>>> cat("send.py")
import socket, os
p = '/sd/1.jpg'
n = os.stat(p)[6]
s = socket.socket()
s.connect(('192.168.4.16', 6001))
s.write('back.jpg,' + str(n) + '\n')
f = open(p, 'rb')
g = 0
while True:
   b = f.read(1024)
   if not b:
       break
   s.write(b)
   g = g + len(b)
f.close()
s.close()
print('sent', g)
Now the recv.py
>>> cat("recv.py")
import socket
s = socket.socket()
s.bind(('0.0.0.0', 6001))
s.listen(1)
c, a = s.accept()
h = c.readline().decode().strip().split(',')
n = int(h[1])
f = open('/sd/' + h[0], 'wb')
g = 0
while g < n:
   b = c.read(1024)
   if not b:
       break
   f.write(b)
   g = g + len(b)
f.close()
c.close()
s.close()
print('got', g, 'of', n)
Now for PICO2
the send.py
>>> cat("send.py")
import socket, os
p = '/sd/cars/1.jpg'
n = os.stat(p)[6]
s = socket.socket()
s.connect(('192.168.4.1', 6001))
s.write('1.jpg,' + str(n) + '\n')
f = open(p, 'rb')
g = 0
while True:
   b = f.read(1024)
   if not b:
       break
   s.write(b)
   g = g + len(b)
f.close()
s.close()
print('sent', g)
For the recv.py
>>> cat("recv.py")
import socket
s = socket.socket()
s.listen(1)
c, a = s.accept()
n = int(h[1])
g = 0
while g < n:
   b = c.read(1024)
   if not b:
       break
   f.write(b)
   g = g + len(b)
f.close()
c.close()
s.close()
Now in our main.py
>>> cat("main.py")
import network
ap = network.WLAN(network.AP_IF)
ap.config(essid='pico1', password='pico1234')
ap.active(True)
synctime()
for the pico2
>>> cat("main.py")
import time
time.sleep(6)
wifi('pico1', 'pico1234')
This what I used to transfer a 440Kb file first via teraterm which was corrupt so setup my SDCard reader and putting the .py files on was easy. Now I did setup to the hotspot on my phone and left it going when we did the file transfer and the phone showed 0 data so the wifi just worked.
Now the file was 1.jpg which is a jpg file I got off the club page which is a car photo, now got the error progressive jpg files not supported so although the picture didn't show transferring it did.
Now after a day with Claude this what it had to say....
Sounds good. If it's useful for the writeup, the summary of where things landed: two Pico Computer 3 boards, one as AP and one as client, both coming up connected at boot with no intervention; TCP file transfer working both ways with a 441 KB JPEG as the test; and a SQLite-backed club system with member, cars and events pages on the HDMI GUI.
The AP-mode finding might be the most useful thing for other people there — it fails consistently if you reconfigure the interfaces live, and works reliably when each board sets its role once at boot from main.py. That cost us most of a morning and isn't in the manual.
Now what we came up for Day 1
club.zip
Now doing a ls("/sd")
>>> ls("/sd")
    <dir>  2024-12-06 10:22  Camera
    <dir>  2026-08-01 16:21  events
    <dir>  2025-09-01 16:02  Games
    <dir>  2026-08-01 12:55  members
    <dir>  2024-10-09 16:43  Music
    <dir>  2025-09-02 11:13  Programs
    <dir>  2025-08-26 09:06  System Volume Information
   440973  2026-08-01 11:21  1.jpg
     1948  2026-07-22 15:34  car_meet.py
     2051  2026-07-22 10:07  car_meet.txt
    11283  2026-07-25 11:14  carclub.py
    45056  2026-08-01 16:50  club.db
    23625  2026-08-01 16:50  club.py
     5654  2026-08-01 17:20  club.zip
     1688  2026-07-25 23:43  import_members.py
     4748  2026-07-25 23:43  main.py
      189  2026-07-23 15:18  members.csv
      126  2026-07-23 15:18  members.csv.bak
     8192  2026-08-01 16:31  members.db
     7011  2026-08-01 14:39  members.py
     2915  2026-08-01 04:35  menu.py
       42  2026-08-01 13:26  roles.txt
       18  2026-08-01 13:26  status.txt
we can see the club.py file is at 23Kb and best of the club.db file is 45Kb and once I did that this what Claude said
It's there — 23,625 bytes, timestamped 16:50. The 3456 figure was from the earlier listing before the transfer.
Better still: club.db exists at 45,056 bytes, same timestamp. So you've already run it and SQLite created the database with all five tables. That's the whole thing working.
Slight size difference from my 22,960 — probably line-ending conversion during the transfer, which is harmless for Python
So now decision is do I work on this tomorrow or go on a car meet drive to Lamaroo to play golf and get closet to the hole. I haven't taken my 1996 C200 Mercedes out since I transferred it over to historic rego.
Regards Bryan
Edited 2026-08-01 18:01 by Bryan1
