thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4395
Posted: 01:11pm 25 Apr 2025
Thanks Phil, AI regurgitated something similar at me but it also said: Quote It's worth noting that modern USB-C connectors have built-in support for similar functionality without needing special cables, as the USB-C specification includes the ability to negotiate roles and power delivery. However, for devices with micro-USB ports, the OTG cable remains an important accessory for expanding connectivity options. and Quote For connecting a mobile phone with a USB-C port to a wireless dongle with a USB-A connector, you typically don't need a specific OTG cable. A standard USB-C to USB-A adapter or cable should work in most cases. Here's why: 1. USB-C Capabilities: - USB-C is designed with built-in support for USB On-The-Go (OTG) functionality. - USB-C ports on mobile phones are generally capable of operating in both host and peripheral modes without needing special signaling from the cable. 2. Host Mode Support: - Modern smartphones with USB-C ports are usually configured to enter host mode automatically when a peripheral is connected. 3. Power Delivery: - USB-C ports on phones can typically provide power to connected devices without needing a special OTG cable. 4. Adapter Compatibility: - A standard USB-C to USB-A adapter should allow the phone to recognize and interact with the wireless dongle. However, there are a few considerations: 1. Phone Compatibility: - Ensure your specific phone model supports USB OTG functionality. Most modern smartphones do, but it's worth checking. 2. Android Settings: - Some Android phones might require you to enable USB OTG in the settings. 3. Power Requirements: - If the wireless dongle requires more power than the phone can provide, you might need a powered USB hub. 4. Quality of the Adapter: - Use a good quality USB-C to USB-A adapter to ensure proper connectivity and functionality. 5. Software Support: - Make sure your phone's operating system supports the type of wireless dongle you're connecting (e.g., for Wi-Fi or cellular dongles). In summary, for most USB-C equipped smartphones, a standard USB-C to USB-A adapter should be sufficient to connect a wireless dongle with a USB-A connector. The OTG functionality is typically built into the USB-C port and the phone's software, eliminating the need for a specialized OTG cable in most cases. I guess the difference here might be whilst the R36S has a type-C port labeled OTG that doesn't mean it has all the necessary smarts of a modern Android phone. Best wishes, Tom
